Six_Silver
- Sep 10, 2003
I would like to know how well a t400 works with a stock 3.42 gear. For those of you using this setup, did you have to change the gearsets in the trans? This will be for a mid 10 car at 3700lbs.
SignUp Now!I dont want to change the rear gear from 3.42 to 3.73 though. I am looking for responses about the stock 3.42.Originally posted by chris718
2.482/1.482.works great in the 10 second zonewith 3.73 final drive .if you want a custom ratio give me a call.
Originally posted by ttypewhite
Chuck Leeper- Wow, that mph is killer, what happen to the et, outta curiosity? You should be in the 9.60 to 9.50 area with awesome top end charge.
No No, James. He is talking aobut changing the gear set inside the transmission.Originally posted by Six_Silver
Right but he said with 3.73 final drive. That doesnt apply to me since I am asking about a 3.42 final drive.
I would like to know if anyone in the mid 10 second range is using a stock (3.42 rear end gear or "final drive" gear whatever you want to call it) with the "stock" t400 gearset. If the gearset in the trans is not stock, what are you using?
