Ktbregal
- Nov 4, 2012
Would you recommend a screw on or remote. I am running no oil cooler,just filter?
SignUp Now!It helped mine about 5 lbs , but oil flows so much better with no paper element
K&P Engineering’s reusable oil filters offer faster oil pressure at start-up.More filtered oil gives you longer asset life for your vehicles.
Up to 7 times more oil flow than paper filters.
Environmentally friendly
Remote increased my oil pressure and is easier to remove and replace with out the mess at the block, plus I always fill the filter with oil when replacing it to decrease start up starvation.I am sold, just wondering if a screw on is just as affective as a remote?
Why would anyone block the bypass???
the oil filter bypass will bypass dirty oil past the filter on startup and other times that the filter poses a restriction. This is not the same as the main pressure bypass which only controls the upper limit of oil pressure.Why would anyone block the bypass???
http://kandpengineering.com/Where can someone finds these k&p oil filters
so no one uses stock untouched type covers or HV units these days like the ones offered by fullthrottle?
Watching that movie it looked like he spent $3 on brake clean and $10 worth of time lol. I'm lazy I'll stick to my Napa Gold (wix) filters on the turbosaver lolYou forgot one other important item Kip, it will also pay for itself in the long run as you only buy a K&P filter once!![]()
Ultimately if the filter bypass is blocked and the filter can't flow enough 1 of 2 things happen. The filter will either collapse and/or blow a hole through the element.
Blaming a hv pump for wearing out the front cam drive/ bearing when the bypass is blocked off is a total misdiagnosis. Blocking off oil bypasses and running too much oil pressure loads the pump drive way harder than bigger set of pump gears... I can't believe this goes right over everyone's heads.
Ultimately if the filter bypass is blocked and the filter can't flow enough 1 of 2 things happen. The filter will either collapse and/or blow a hole through the element.................
I just want to add my comments and opinion in this discussion based upon many years of dealing with Buick engine oiling starting with Buick engines before the turbo days.
It is not unusual for oil pressure of 80-90 psi when starting an engine on a " cold" day here which is 30-40 degrees, and about 35-50 psi at operating temp.
The issue I did have with these cold start oil pressures, the paper-type cartridge filter would collapse, or at least develop "tracks", or wide openings to allow oil to flow which means it is not filtering some oil even with the by-pass closed?
Some of the more expensive filters have a very fine media which actually restricts oil flow, and filtering oil down to 8 microns is counter-productive. I prefer to have more oil flow and pressure.
The Wix filter for example has a 60 micron media, which is adequate for protecting bearings and other parts.
Also, the cleanable filters use a 40 micron stainless steel mesh screen with NO bypass, and this is what we prefer to use especially to protect our expensive performance builds.
Our testing has shown an increase up to a 10 psi oil pressure across the entire RPM range with the mesh filter, which in our builds is 80-90 psi at high RPM.
I have well over 1000 passes in my race car over the years and never trashed a main bearing, and has fresh bearing every season.
