Mr Spool are you reading manifold pressure?
62 is a way better option on a 3.8l. Especially over 22 psi compared to 49/44...way more efficient.
If you are reading manifold pressure you have to subtract atmospheric pressure which is 14.7 psi at sea level and drops as you climb to higher elevations. So I could read 36 psi MAP - atmosphere of 14.7 and get 22 psi "boost" (pressure above atmospheric pressure.
This is a common mistake and explains why some people think the Duramax gets 36 PSI of "boost". You are only getting 22 psi of "boost". To make things worse the GM service manual implies you get 36 psi of boost when they mean 36 psi of manifold pressure (above a vacuumpressure which is 14.7 psi at sea level and drops as you climb to higher elevations. So I could read 36 psi MAP - atmosphere of 14.7 and get 22 psi "boost" (pressure above atmospheric pressure).
He is talking 30+ psig, so 44+ psia, which you are calling manifold pressure.
