TA60 w/stock waste gate
86SS86LS
Can a TA60 be used with a stock waste gate? I'm considering purchasing a used TA60 that is currently using an external wastegate. And will the TA60 pretty much bolt up in place of the stock turbo?
Yep...
check your puck, to insure it closes over the bi-pass, and if you have the time. you might want to port your stock elbow to take advantage of the extra boost.
Btw...
You don't list any mod's, but you probably should have a chip burned for the added air volume, so as not to lean out. Try Eric (turbotweak) for your chip. You will see a good all around performance increase w/o the need to replace h/g's. Remember to tune for no knock.:)
I should have mentioned, it does have a 3" down pipe, 50 lb injectors, and a TT e85 chip.
