TA61
TTipe
Snake Skinner
Heavily modded TA61 had coking at the journals. Looks like coolant got into the center housing. Does someone know if the TA61 is a culprit of shaft flexing from wheel weight?
Its not subject to shaft flexing under normal conditions. Much heavier wheels have been used for years with no problems. The shaft should be .250" at the compressor wheel bore and the journals .400" The ex wheel could be a p trim, t04 69 trim, a stage 3, or possibly a stage 5. Ive seen them all called TA 61 when coupled with a 60-1 compressor. Ive seen GT35r compressor equipped turbos called TA61 also if in a stock cover. Coolant entering the cartridge wouldnt matter unless it was a lot of coolant and no oil. You would have rapid trust failure with no oil and the bearings and journals would show it. The shaft needs to be within .0001" or you will not be able to balance it. If its out of balance because the shaft it bent you will definitely hear it and it will likely wear the back plate bore rapidly.
Mine appears to be a 60-1 with a to4 69.I'll try it again with the new engine and trans.
Thats a good combination of wheels. I went 124+ with those in a t04e cover (PT54). I dont know the exact limitation of the stock cover but it doenst choke flow the 60-1 too bad on low rpm applications with low mass efficiency. You will drive through that converter before you can take full advantage of that turbo
