tail shaft housing
Super6
i need one of these for a th400...i need the short one...........thanks Bob
Bob you have to let people know if it is a small yolk or large. Bruce told me the large one has a letter C cast on it. And he was right. They are not that hard to find. Just wanted to let you know. BTW if you had the same problem I had re check your lenght for your drive shaft mine was 1 inch too short.
Steve
thanks Steve
it is the large...the yoke from the GV's has the letter c (spicer) stamped on it. i am going to use the spicer yoke for front and on the rear. the rear output on the trans is 1.38" and is 4 1/2" long from where the housing bolts up....thanks again.....Bob
