77 cruiser
- May 24, 2001
I have a set of Raybestos tan frictions. Will they work in the directs, dual feeding?
SignUp Now!How much power do you plan to put through it? Cruiser or drag car? For the cost I would do some thing fancier. You don't want to have to do it twice and I don't think there is a down side to using a red clutch. That said I didn't dual feed and I did use a raybestos red stage 1 clutch in the direct.
RC told me 10.50 or faster blues...I don't plan on going that fast. Pressure and calibration are not a problem![]()
Thanks Pat see you soon.What he really means is for your application installing blues is a waste of money......they will work just fine but for that power level the red altos will like too...hell i had all reds in my trans for a good while at 9 second power
Very true. What I am starting to see with the NON FACE GROOVED red metallic plate in the 2004r, and only the 2004r,not the TH400, is excessive open clutch pack drag. The spin losses show up in the form of polished steels even on units with an undisturbed friction apply surface. The antirotation encountered by the direct clutch housing is higher than average due to transmission ratio, requiring a minimum of .010" clearance per clutch plate. If the plates have grooves there is a better chance of survival due to the grooves ability to disrupt laminar film between held and driven clutch pack members. The grooves however, reduce overall clutch capacity. With the TH400, an over-engineered transmission to start with and the grooves only make the good design even better.Stock frictions will live in a low 10 sec application if the calibration is correct. Clutch type isn't going to remedy a poorly calibrated leaking hydraulic circuit.
