- Jan 18, 2011
What ever the turbo you decide go for the alky, you not gonna be able to stop at 20psi, its like a drug...
SignUp Now!The shield will fit the turbo. The downpipe is what determines if the shield will fit.
At 20psi, keep the stock turbo. You will only add lag with a 44.
I love theAbsolutely disagree! or IOW, wrong! But what the hell do I know, I've only been running the same TE44 for almost 20 years now.
You guys that run the huge high numbers like you are have probably forgot years ago how nice a turbo it can be. And if he isn't convinced about the 44 then he can always go with a TA49.
I have a 44 on my GN been on there since 99 .I run 19 psi on on 93 with good results .With that said there cars need a combination or recipe to work properly .there is a correct order and way to do things right or you can spend a ton of money to go slower
a 44 will not help but will hurt performance if you dont do it right with the correct parts to assist in the recipe .best time on my unopened engine was 11.69
mine didDid you have surging with the 44 and front mount?
actually I remember how much fun it was.49 turbo ran awesome on my car high 10s at 125mph.60000+miles on the turbo before I bolted it on another stocker and the guy loved it.You guys that run the huge high numbers like you are have probably forgot years ago how nice a turbo it can be.
I saw the thread you started.looks like data that you are sharing is there other data that you are looking for?Just started a thread for real data on the TA 49 or TE 44. Post it if you have it.
If anyone has hot boost vs manifold pressure and inlet and outlet temps I'd be interested. Has to be accurate data thoughI saw the thread you started.looks like data that you are sharing is there other data that you are looking for?
egt probe info taken preturbo on a 10sec 49 car with stock ecm/maf.Has to be accurate data though
It's useful if you can overlay the timing and a/f numbers over itegt probe info taken preturbo on a 10sec 49 car with stock ecm/maf.
I ran twin m10 nozzlesEveryone is entitled to their own opinion but Julio meth kit is one of the top ways to go for a boosted street car. Get the boost up
I can, I would rather pm you the infoIt's useful if you can overlay the timing and a/f numbers over it
I love the 44/49 with a stock engine. I ran one into the high 10s. There just isnt a big power increase until you turn up the boost. At 20psi, you might see a slight gain over a stocker, but you need to be over 22 psi to really see a difference. I went 11.72@114 with a stock turbo too, with a 1.73 60', incorrect reman converter.Absolutely disagree! or IOW, wrong! But what the hell do I know, I've only been running the same TE44 for almost 20 years now.
