Like Woody said, its easy to say, but not to do. I'm still working on it. You can't just throw the parts on it and run the number. If that were the case, I'd have run 10's 2 years ago. I had the mph for it, but no 60'.
As far as the turbo, I am going to have to disagree with azgn here. I have a 45A on the car right now. Boost can be set at 15 lbs at the lowest, with my hd actuator. I did have to relocate the actuator for better alignment, before 18 or 19 psi was the lowest. On my car right now, I have a 3200 single disk lockup vigilante, and it spools like mad. I dyno'd it and it even suprised the operator! It is a little violent for street use. Rolling into the throttle on anything but slicks nets tire spin. It goes from 0 psi to 15 very fast, resulting in loss of traction.
I noticed you are in the 12's still. I don't think you can just "skip" the 11's. Might I suggest modding slowly and learning to ring the most out of what you have? If your 60' is that bad now, I'd hate to think what it would be with more power! I'm fighting the same problem, and hopefully its better now. HTH
