Intercooler
- May 24, 2001
Sounds like a few guys at an Amway convention :smile:
If ANYONE can't see this is yet another attack on Jack and his IC then they are blind. I still don't understand what Jack did to piss this group off leading to these attacks. If you don't want to buy or run his IC then leave him be. From the looks of it NONE of you are! It still amazes me that you only attack him. How about those units that are even less as found by "The Source" testing like the PTE, Applied and Eastern IC's????? Pretty much even you guys through your own way of testing have shown that in the upper 9's an IC almost double the thickness made a gain that can't even be seen. And the fact still remains that SOME have ran even faster on Jack's IC including Jack. At this point I really don't know why everytime you tune into one of these boards a bash Jack and his IC thread is somewhere to be found
HEY GUYS........... If you are an Upper Cruster needing such a unit then buy the SOB!!!! Nobody disputes that at each level it calls for a different piece. This is common knowledge since day one when you buy ANY part for a Turbo Buick... be it injectors, pump, converter, etc....
Do you guys need a picture of Anderson's TSO IC again so you can see the difference? When you are at that level which some are then if it isn't residing in your car then you are the ASS. Plain and simple what goes with what
