built "109" shortblock
wiseco forged 40' pistons
re-freshen rods
flat tapped conley spec 2 225' cam
timing cover
cam sensor
speed pro moly rings
melling high volume oil pump
biggie oil filter adapter
fully balanced
$1,900
Ported duttweiller heads
fully ported by duttweiler
bigger valves
comp springs
hardened pushrods
recently freashen
950$
kenne bell upper polished plenun,stock lower intake
fuel rails
kenne bell 70mm throttle body
kenne bell fuel regulator
400$
innovative t70 BB turbo
polished compressor
63. powdercoated exhaust housing
$950
aluminum log 6 engraved tall valve covers with breathers
100$
built 200r4
transbrake
red line internals
art carr NL 3200 billet 9in. stall
hardened shaft
2000$
stock turbo headers
300$
Terry Houston 3 in. mild steel down pipe
450$
nick micale custom 3 row radiator w/ fans
$250
200amp alternator with boost resistant
225$
mass air meter stock 3in.
100$
1986 buick grand national
paint 7 out 10
interior 7 out 10
no rust at all
rustelium paint undercarried and floor pans
never wreaked
pro star wheels all around (15 3.5 front with kuhmos tires, 15 8.5 rears with bfg ta tires)
3 in custom conley exhaust
aluminum drums
manual brake setup
aluminum metco control arms
hot wired fuel pump wiring
250lb fuel pump
auto meter full gauges
4500$ RoLLer
re-freshen rods
timing cover
cam sensor
fully balanced
$1,900
bigger valves
comp springs
hardened pushrods
recently freashen
950$
fuel rails
400$
polished compressor
$950
100$
built 200r4
transbrake
red line internals
hardened shaft
2000$
stock turbo headers
300$
450$
$250
225$
100$
paint 7 out 10
interior 7 out 10
no rust at all
never wreaked
aluminum drums
manual brake setup
250lb fuel pump
4500$ RoLLer
