77 cruiser
- May 24, 2001
The forward clutch clearance is right on the high limit of the trans. I`m building. I have another press. plate but it is thinner. So is it acceptable to use the thinner plate & add an extra steel,by doing this it puts the clearance at .012 which is close to the min. of .01.
If this is OK to do would it be better to put the extra steel between the press. plate & friction or at the wave plate & the inner steel.
Jim
Jim
