COMPLETE BOLT IN UNIT /NO CORE CHARGE CKPRO TREE BRAKE WITH REVERSE PATTERN FULL MANUAL VALVE BODY/ MODIFIED CONVERTER CHARGE CIRCUIT TO ELIMINATE THRUST BEARING FAILURES WITH THE 3.8 TURBO BUICK ENGINE
Stage 1 TH400 is built for street/strip, and drag racing vehicles producing up to 750 horsepower/750 foot pounds of torque Each transmission is professionally assembled and given a thorough DYNO test.
COMPETITION COMPONENTS
Heavy duty direct drum with 34 element sprag and spiral retaining ring,OR CUSTOM 36 ELEMENT OVERSIZE SPRAG AND DRUM ASSEMBLY. New GM output shaft with hardened output shaft splines. Heavy duty intermediate clutch snap ring.Custom intermediate snap ring retainer assembly for transbrake equipt units. Rollerized forward clutch hub and output shaft. Heat treated stator tube.New factory deep pan and high flow filter.
CLUTCH AND BAND UPGRADES
5 friction forward and direct clutch packs, and updated 4 friction intermediate clutch pack. New front and rear band.All new forward ,intermediate and direct clutch 1 piece return spring assemblies.
HYDRAULIC UPGRADES
Increased line and lubrication pressure and volume.Modified converter charge circuit . Solid Teflon sealing rings installed on the pump and center support. Special direct clutch case seals and dual feed direct clutch triples clutch apply pressure. Custom CKPRO TREE TRANSBRAKE VALVE BODY,THE FASTEST RELEASE APPLY AND HI GEAR SHIFT EVER
1299.00 SHIPPED ANYWHERE IN THE CONTINENTAL USA.2 UNITS
HYDRAULIC UPGRADES
