...but I like keeping things as simple as possible so that when I have to change out parts during a PM, I'm not having to modify parts over again.
Yes the valve is pre heat treated before it is machined.mike ridings gave me the material # and I ordered it .i think it is called 4310 preheat treated billet.mike can chime in with the specs.
I not clear on what you mean, .002" per side. I hope you're not talking about a total valve to bore clearance of .004".thanks mike.i used it for those stagerite valves as well.after grinding i put them on center i put them in a v block and they were unmistakably 0.it was impressive.the grinder did a good job and we left .002 per side.great material,and priced reasonably.mike when you use that 700 bearing on the rear of the pump support you must grind off the lip or relieive the front bore on the drum.i have also been having great luck using the new style 4l80e support rings in the 400.they are a plastic/graaphite combo and have a unique interlocking desin that seals and doesnt shrink and also doesnt erode the drum bores.they are shown in the photos from turbobitt
I keep finding new mods for the 400 all the time:
http://www.bdub.net/tranny/TH400SuperBeefing-text.pdf
The pump drilling was new to me. I already knew about the .072" steels.
Also, a guy on the RealOldsPower board found this in his 400 oil pan:
http://img174.imageshack.us/img174/1376/vxlqa0.th.jpg
ImageShack - Hosting :: vxlqa0.jpg
"The center part is rubber..
The other part is aluminium, not the sprag then."
Time for a new case for him?
Definitely overhaul time!
That's a safe line. I run 200 in mine, but the shifts are pretty firm and I've been thinking of lowering it a tad bit to save on the int. snap ring lugs of the case.
I would hope your using a HD sprag on the int. And I'm sure you are. The OEM HD sprag arrangement should handle your specs. The lower line you're using will cushion the int. apply and will mean lower shock loading of the int. sprag. Less chance of a roll-over of the sprag. I didn't say no chance, because you are using a larger plate count in that pack now. If you are using the wavy in the int., you might want to periodically check that pack to see how that wavy is doing, as far as localized heat buildup.
The reason I asked about seeing the drum was because of the steel piston you're switching to. Early drums that used the sprag type one-way clutch setup had an air bleed checkball in the aluminum piston. If you switch to the steel piston, you must use a drum that has an air-bleed checkball in it. You can use a drum and a piston that have the air bleed checkball. But you must have one or the other or both. Not zero.
don .002" per side is the amount left for the grinder to grind off to bring the valve to the proper dimension.this means if the part finished od is .750 its diameter is machined to .754 "after turning in the lathe .the final material removal to get to required diameter is done on a grinder while the part is supported on both ends from a center point machined into both end faces..002"per side removed generates .750".besides other things it allows "exact finishing and alignment between centers.
jason high rpm engines benefit from no check back on either side but a mandatory .060 bleed hole in the drum.hi rpm can cause balls not to seat.
Testing i have done in the past has improved clutch apply with balls omitted in high rpm applications.Oil does momentarily exhaust out the ball on apply and it is this motion that partially pulls the ball into the pocket to create the seal.Hi rpm can throw the ball up the curvature of its pocket and away from the center and unseat it.Oil pressure acting on the balls minute cross section in psi is minimal at best,and there comes a point where rpm beats psi.
