Scott89TTA
- Jul 12, 2005
Finally placed & now have received my order for my new upgrades for the TTA from Full Throttle :biggrin:
I would like to give a big thanks Mike for his guidence and Marriane for givining me a sweet package deal...you guys are great
This is what's happening over the winter !
Currently on the car:
1. TT 93 street chip
2. 160 t-stat
3. RJC power plate
4. 3" alum. "Grumpy" MAF pipe
5. 9" K&N
6. 3" Action Fab S/S DP w/ported stock elbow
7. 3" cutout w/QTP electric dump
8. MT DR's (ET Streets) 255/50-16
9. Scanmaster
10. Stock Trans w/PTS shift kit and .570 pressure valve (replacing with trans listed below)
11. 100# valve springs
12. rerouted PCV and breathers on both valve covers (driver side vc on pass side as well)
13. MSD 8.5mm Super Conductor wires
Have but not installed yet:
1. RAZOR Alky Control Kit
2. Bill Anderson fully built bfr 200r4 w/Stagerite Trans Brake, good for mid-low 10's.
3. PTS billet 9/11 3400-3600 stall convertor
4. Racetronics Hotwire kit
5. RJC manual boost controlloer
6. HRpartsNstuff poly motor mounts
New parts from Full Throttle are now sitting here at home waiting to be installed:
1. GT6776e Turbo
2. HD actuator
3. Walbro 340M fuel pump
4. Accufab billet adj. fuel pressure regulator
5. 60# Siemens/Motoron High-Z injectors
Still need to pick up a trans cooler and new TT alcohol chip then I will be done for a while.
Scott
2. 160 t-stat
3. RJC power plate
5. 9" K&N
9. Scanmaster
1. GT6776e Turbo
2. HD actuator
Scott
