EightSecV6
MDBL
- Jul 18, 2001
First of all it is a terrible thing to hurt such a beautiful car, I feel really bad for Mr Sullivan but he will fix the car regardless of how much work it takes, it's his GNX and he has no desire to scrap it or sell it so the value really wont matter. I was running against him in qualifying on that pass. I was shutting down and he passed me at well over 100mph but it seemed as if it were in slow motion,the car stopped suddenly and a big cloud of dust flew into the air.I was the first one to get over to him as soon as I could get stopped, I flung the door back and unbuckled his harness.I asked him numerous times if he was OK and all he said " I'm fine (pointing to the hood) but would you look at this?" His hands were bleeding pretty good but I can honestly say I was much more shaken than he was as I expected to see MUCH worse when I opened the door. John had just run a 10.2? at 135 in a normally high 9 second car, he told me he was pushing the brake as hard as he could but the car would not slow down. I have seen mention of shifting in neutral, turning the key off etc etc. You only have a fraction of a second to make a decision at this speed and I am 100% confident that John did the best he could to save the car, it just didnt work out.I think it would be a safe assumption that "if" the throttle were stuck on a 3600# car that had 800hp and was already travelling at 135mph, all the powermaster in the world wouldnt stop it. John said that he tried to get to the e-brake but the cage (probably the part that saved his life) got in his way and he could not get to it. Once things settled a bit, I went in the ambulance to see him and the first thing out of his mouth was " hell, you already had me beat, why did you have to run me in the hay bails?
". His wife commented " I think the hay gives it character". Bottom line is the car is a wreck but it can be repaired and John walked away from it virtually uninjured. I am glad he took the precaution to set the car up safely (even if it is a GNX) to run the ET it is capable of or this scenario would have been alot worse. Some events dont enforce the safety rules but accidents like this should really make you consider it for YOUR own benefit. Norwalk was definately the most strict tech I have ever had at a Buick event and for good reason. Good luck on getting the car back together John, I hope I get the oppurtunity to race with you again soon!
