The last Oil Filter you will ever buy! The Best and the Baddest!
WE4
TBcom Admin /Prayers NYFD/NYPD
PTS Xtreme has joined forces with K and P Engineering to bring to the Buick and automotive world, the latest and greatest and the last oil filter you will ever buy!!!! The engine condition can be checked every day if so desired! Filters down to a true 35 microns and completely washable and reuseable! We are also using these with a remote oil filter for the transmission as well!!!! You can ck the condition of the trans daily!!!
Below are the facts and FAQ's that are asked about this product. We are stocking distributers for this oil filter which comes in black or grey anodized, chrome and my favorite and cheapest, Billet Aluminum. Kit comes with filter, extra oring, tool for removal and installation, and a polishing cloth for the billet filter.
As fast as we get these, they are going out the door. These filters outperform the System 1 and the Oberg filters and like I said, can be cked daily if so desired. Here are the facts and nothing but the facts below.
Questions and orders can be emailed to : PTSXTREME@aol.com
Pricing is as follows:
Billet Style: $159.99
Anodized Style: $164.99
Chrome style: $184.99
(plus Shipping of course)
(Dealer Pricing Available over a 12 filter order.)
Man, I haven't even finished posting this and I already have had three orders while I am putting this up.!!!!!! I cannot believe this!
Stainless Steel
Micronic Oil Filter
 Cleanable
 Proven Technology
 High Flow Rate
 Superior Filtration
 Easy Filter Element Inspection
 Unaffected by Water, Heat, or Pressure
 Environmentally Friendly
The filter is made from medical grade, type 304 stainless steel micronic filter cloth providing unmatched protection against oil contamination and resultant engine damage. A one-inch square of this material flows an incredible 1.9 gallons of oil per minute at only 1-PSI pump pressure. The adhesive used in the filter assembly process is good to 600 degrees Fahrenheit, far above normal engine operating temperatures. A super strength nickel-plated neodymium rare earth magnet is installed in the top of the element for magnetic pre-filtering of the oil. The unique twist lock design allows for easy disassembly, inspection and cleaning. The quad-ring gasket doubles the seal between the filter and the engine. Finally, the filter housing is carved out of solid chunk of 6061T6 billet aluminum, which not only looks trick but aids in dissipating heat.
 Inspect and clean the filter prior to initial use
 Use care when handling the filter element
 If you are unsure of any of these procedures contact a reputable mechanic for assistance.
Cleaning Instructions
At minimum, clean the filter with every oil change. Remember, oil is the lifeblood of you engine- keep it clean!
Gently push the filter element straight down out of the locked position, twist filter element 1/3 turn counter clockwise and release. You should now be able to remove the filter element from the housing.
Wash the stainless steel filter element, spring and housing in clean solvent, kerosene, aerosol carburetor cleaner or any other degreasing agent; even common dish soap and water. If inspection of trapped debris is desired, flush the particles into a clean light colored container. Once clean, lightly blow air through the filter from the inside out to remove any remaining particles or cleaning agent from the screen.
Assembly And Installation
After all components are clean and dry, place the spring in the filter housing, large down (toward the housing). Now place the filter element into the housing making sure the three “ears” on the element fall into their slots in the housing. Gently push the filter element straight down into the housing, twist the element 1/3 clockwise, and then let the element spring back up into the locked position. Make sure the three filter element ears are fully engaged in the housing notches (as the filter tightens on the engine, the filter element will tighten against the housing which will eliminate any play).
Install the rubber quad-ring (either side up) fully into the groove in the housing. Lube the quad-ring surface with a thin film of clean oil and install filter on engine. The filter should spin on at least 3 full turns. Torque the filter to 20-25 ft. lbs and recheck torque after 100 miles.
For more info and more pics go to KandPengineering.com
Call for pricing and availability. From ATV's to Motorcycles to Racing Automobiles, Street Trucks and Street Cars. We carry them all!!!
More pics of this GREAT Product!
The Last Oil Filter You Will Ever Buy!!!
More pics!!
Killer piece!!
This is one of the most awesome products to come along in a long time!
These filters are KILLER! They are selling like crazy. Even the State of Ca. is interested in the "green enviroment" they help to assist with. No more storing, draining and crushing oil filters for recycle. Man, these things are cool!! Everyone around here has put them on their cars. Now we have all makes and models in stock. Fords, chevys, and of course Buick. Motorcycles and atvs as well.
Man, great product!!!!!!
Yes they filter down to 35 microns, a TRUE 35 microns. The human white blood cell is 15 microns. Do not beleive what they say on the paper filters. They "Claim" they filter down to 35 microns but they do not. The best they go is between 90-135 microns. It is the way they "test" them. What we are telling you is the truth. I can even hook you up with the designer if any super highly technical questions need answering.
This filter can be 80% plugged and still flow more oil then a BRAND NEW Paper element!!!.
Best product to come along in a long time!
Bruce
We4
Performance Transmission Services
Call for any more info.
916-739-0510
You guys should get in on this!
These are selling nicely. EVERYBODY who has one LOVES them! They are the best product for our cars to come along in a long time. Now , the State of California wants them for the CHP cars and BMW bikes. They are considering their fleet cars as well. No more storing and disposing of oil filters and can ck condition of engine at every oil change preventing a broken down car, a tow,and a stuck employee. We all know, that "State employees take very good care of their state cars.LOL" :rolleyes:
Anyway, neat product and I am discounting them to our members. Freight free.
Take advantage of this product. I am sure you will be more than impressed.
Bruce
We4
Everybody Loves Them
WE4,
Have any tribologists/oil experts reviewed this product? Has it appeared on any oil sites such as Bob Is The Oil Guy
Your comments are appreciated.
Come up with a 20 microns filtration filter and I will buy one, I dont think 35 is enough, system 1 offers a 45, 30 microns filtration with thier purchase thats the only thing that stop me from buying one.. get me a 20Microns and I am sold.
I'm going to be devils advocate here. Shouldn't this be on the "for sale" or "venders" section?
to high for me
price is a littel high!!! its just a oil filter nice looking one . BUT still a oil filter. i can think of other things my car needs for 180
Yes they have..
WE4,
I will be posting quite a bit of more tech info here shortly. Including, Bob the oil guy, " who I didn't even know existed. They (K & P Engineering) are composing a section on "micron measurment" so it can be truly understood how and what you are interpreting. I , myself, am looking forward to this.
Keep cking back. I should have it today or tommorrow.
Till then
Bruce
We4
Ok here is the "Real deal" on filters. Plus testimonials.
Bubble Point Pressure Test, Pore Calculations and Flow Test for Various Oil Filters
Click on the attachment link on the bottom for the chart.
oilfilterstudy.com Non-bold/indented not PF1218 equivalents. Italics is Merc application.
Testing details and formulas are outlined below Sorted by smallest pore size
Filter Material Glycerol 30W 30W Glycerol 30W Average 30W
# Type 4cc/min 4cc/min 40cc/min Largest Largest large pore Smallest EFA
Grams of
Flow
(ml/cm2)
/min
(fl-oz/in2)
/min
Grams
of Flow
(ml/cm2)
/min
(fl-oz/in2)
/min
1 Fram TG5 0.85 0.68 1.9 41 40 41 15 1.8 274 35 4.0 0.85 40 9.2 0.05 .035, pressed cellulose, ridged, var. thickness*
Fram TG2 (FL820s) 1.2 185
Fram TG3600 (FL400S) 1.3 194
2 Purolator PureOne PL34631 0.86 0.64 2.7 40 43 42 10 1.7 330 27 3.1 0.66 30 6.8 0.04 .026, pressed cellulose
Purolator PureOne PL24651 (FL820s) 1.2 236
Purolator PureOne PL20195 (FL400S) 1.0 201
3 AC UFP1218 0.86 0.61 1.8 40 45 43 15 1.3 194 34 3.9 0.84 39 9.0 0.05 .025 full synthetic, GMF between nonwoven lams
4 Parker 10=2 Hyd 0.73 0.57 1.6 48 48 48 17 n/a lots .030, pressed cellulose
5 AC PF1218 0.73 0.53 1.6 48 51 50 18 2.7 326 44 5.0 1.07 49 11.3 0.06 .030, pressed cellulose
6 Baldwin B1428 0.75 0.51 1.6 46 53 50 17 2.9 413 37 4.2 0.90 40 9.2 0.05 .029, lightly pressed cellulose, var thickness*
7 AMSOil SDF24 0.73 0.52 1.6 48 52 50 17 4.2 339 64 7.4 1.58 71 16.3 0.09 .026, pressed cellulose
8 AC 35L 0.76 0.50 1.3 46 55 50 22 2.8 216 68 7.9 1.67 68 15.6 0.08 .023 full synthetic, three gradient layers
9 Fram PH5 0.75 0.50 1.6 46 55 50 17 1.4 183 41 4.7 1.00 44 10.1 0.05 .032, pressed cellulose, var thickness*
10 Mobil 1 M1-302 0.73 0.49 1.7 48 56 52 16 2.6 299 45 5.2 1.11 45 10.3 0.05 .038, pressed cellulose, var thickness*
11 Donaldson Synteq (media only) 0.71 0.50 1.2 49 55 52 23 n/a n/a 43 5.0 1.06 42 9.6 0.05 .026 full synthetic, GMF between nonwoven lams
12 Fram X2 XG5 0.64 0.45 1.2 54 61 57 23 4.0 242 86 9.9 2.12 89 20.4 0.11 .052, cellulose?/synthetic, no press**
13 Purolator PremPlus L34631 0.64 0.45 1.2 54 61 57 22 5.5 345 83 9.6 2.04 95 21.8 0.11 .020, pressed cellulose
14 Wix 51060 0.69 0.42 1.4 50 65 58 19 2.9 305 50 5.7 1.22 50 11.4 0.06 .020, pressed cellulose
15 Wix 51086 0.65 0.44 1.3 54 62 58 21 1.9 185 54 6.2 1.33 55 12.6 0.07 .023, pressed cellulose
16 STP S5 0.69 0.41 1.5 50 67 58 18 3.8 326 60 6.9 1.48 71 16.3 0.09 .020, pressed cellulose
17 K & N HP-3002 0.64 0.38 1.0 54 72 63 27 4.7 343 72 8.3 1.77 84 19.3 0.10 .020, pressed cellulose
18 SuperTech ST5 0.66 0.36 1.1 53 76 64 24 3.9 305 66 7.6 1.63 77 17.7 0.09 .020, pressed cellulose
19 Hastings LF279 0.54 0.35 1.0 64 78 71 29 6.1 264 120 13.9 2.96 120 27.6 0.14 .020, pressed cellulose
20 Motorcraft FL400s* 0.53 0.31 1.2 66 88 77 22 3.3 174 100 11.6 2.46 101 23.2 0.12 .022, pressed cellulose
21 Mercruiser 35-80288ST 0.53 0.30 0.8 66 91 78 34 4.7 182 135 15.6 3.33 142 32.6 0.17 .020, pressed cellulose
22 Donaldson P550964 0.45 0.25 0.8 77 109 93 35 7.6 278 143 16.5 3.52 149 34.2 0.18 .030, lightly pressed cellulose
23 Wix Racing S1515R (media only) 0.36 0.27 0.8 97 101 99 36 n/a n/a 154 17.8 3.79 180 41.3 0.22 .032, lightly pressed cellulose
24 Fleetguard LF-3679 0.30 0.24 0.8 116 114 115 34 7.5 277 140 16.2 3.45 160 36.7 0.19 .016, pressed cellulose
Filter Holder n/a 400 46.3 9.85 300 68.9 0.36 Filter Holder
Media measurements (inches), observations &
type
Oil Flow withBubble Point Pressure Calculated Pore Size in μm 25mm filter holder
10psi for 2 min 20 psi for 1 min
Oil Flow @
10psi
gal/min of
30W @ 70°F
FAQ's:
I have also attached a testing results page that was found on the oil filter study dot com site, so that you can see others have found similar results to ours. You will want to pay attention to the average largest pore size for each of the filters.
If someone is really interested true test results, they should not take the word of manufacturers (ourselves included) and should commission tests of their own comparing SAE test results to ASTM, and then deciding which results have the most meaning to them.
Dave Fisher
K&P Engineering
High Performance Reusable Cleanable Oil Filters Made With Billet Aluminum Housings and Stainless Steel Filter Media
Sent: Wednesday, June 18, 2008 7:47 AM
To: 'Dave Fisher'
Subject: RE: Probably a common question!
Dave, thanks for the information, and yes, it was helpful. I know there are no standards… or actually there might be too MANY standards. J I like black and white standards when you can get them, but grayish numbers appear to be the norm with filter specs. How Harley can call it a 5 micron filter when it passes 40 micron particles is beyond me. If they do indeed pass 40 micron chunks, and your filter won’t pass anything bigger than 35, it sounds like no contest. It also looks like the S4 just spins on in place of my present filter, which is another plus. Now I just have to find the place with the best price I guess!
Thanks for your time.
Roger
Roger
Program Manager | Microsoft Office Interoperability
Sent: Tuesday, June 17, 2008 6:12 PM
To: Roger
Subject: Re: Probably a common question!
Hi Roger,
Thanks for your interest.
When it comes to micron ratings, things can get pretty muddy. You can have efficiency ratings, beta ratios, multiple passes, averaging, etc. going on in many of the filter tests that allow you to pick a number that looks good for marketing.
We prefer to test filtration performance using an ASTM test, which gives you a worst case scenario. In other words, what are the largest particles a filter will pass. Using that test, a Harley 10 micron filter passed 48 micron particles, a 5 micron passed 40 micron particles. Now this doesn't mean that the factory filter is bad. In fact, Harley filters return the lowest numbers of all the paper filters we have tested so far. And they work fine. If they didn't, you would have blown engines all over the place. Same with our filters. Since 1995 we have not had one engine failure attributed to our filter failing to perform. All we use the numbers for is to show that our filters, the largest particles being passed at 35 microns, meet or exceed the factory filtration performance.
On the flip side, the finer a filter media is, the poorer it flows. On a pro stock motorcycle at the drag strip, a paper filter measured 20 lbs of differential pressure (the difference in pressure from the outside of the filter to the inside), and ours measured less than 1 lb. What this means is that the bypass valve on the paper filter, usually measuring between 4 and 8 lbs opening pressure, is open allowing unfiltered oil into the engine. At this point, it doesn't matter fine the paper filter media is. Think about cold startups on your engine, cranking the throttle to listen to those cool pipes, the thick oil trying to get through the filter media and going through the bypass instead.
This reduced back pressure against the oil pump is where the horsepower gains come from. Kind of like turning off the air conditioning in your car.
One should also ask how our media can filter as good as the paper media, yet still flow multiple times more oil in the same time frame. This is due to the construction of the media. Cellulose or synthetic fibers, normally of varying diameters and lengths, are pressed or glued together, and are layers deep. Our filters media is stainless steel wire, woven into a fine cloth, producing a much more consistent filtration media with very high flow rates. This also increased the contaminant holding capability. If you do the math, with our filter flowing 5 times more oil in the same time frame as a paper V-Twin filter, ours can be 80 percent plugged and still flow as much as the paper filter.
Add in the fact that you can pull the filter anytime to check the contents for undesirable signs of something going wrong, the outstanding appearance of the housing, the magnet pulling ferrous material out of the oil, the cooling properties of the filter, and you start to appreciate just how much our filter brings to the table. If you are so inclined, since you are not adding oily filters to the landfills, you can even brag about the fact that you are doing your part to be "Green" (as you do a monster burnout and rattle the windows for the next two blocks).
Hope this information helps.
PS If you decide to buy one of our filters, S4 is the part number that fits the Harley applications, both Evo and Twin Cam including the 07 and 08's. (with the exception of the V-Rod which takes an S10)
Dave Fisher
K&P Engineering
dave@kandpengineering.com
----- Original Message -----
To: contact@KandPengineering.com
Sent: Tuesday, June 17, 2008 3:31 PM
Subject: Probably a common question!
Hello –
The internet forums (at least the Harley forums) are abuzz on the subject of re-usable oil filters right now. That’s what brought me to your web site. I’ve spent a bit of time looking through all of your provided information and I have a question – probably one that is so common, you’re really sick of it!
First, I totally believe what you say on your site – I don’t doubt your claims, and your product looks to be top notch. I’ve worked on my own vehicles for the last 40 years and just looking at the nice quality and engineering of your filter housing is enough to make me want one! There’s nothing like good quality tools and good quality equipment to use them on.
Now, on to the standard question. I have a Twin Cam Harley (2005), with cams and a big bore kit, not that that matters. The Motor Company tells me to use their 5 micron filter. You say that paper and stainless mesh are different animals, which is obvious to me. However, a micron is a micron. If you’re passing 35 microns, to me that sounds like too big a particle. The Motor Company leads me to believe that anything bigger than 5 microns is too big. I tend to think they’re simplifying matters a bit.
Can you tell me in plain English, that your filter will filter oil as well (or better) than the stock “5 micron” Harley Davidson filter?
If you can say that, I’m going to go and buy one. And I’ll love it, because it looks gorgeous too.
Roger
Snohomish,WA
  • OilFilterStudydotcomtesting.pdf
Post all this "data" on your website instead of constantly bumping this thread to the top of our tech forum. If someone is interested in your product, they will find your website.
Look, you even have your own Vendor forum further down on the main page, seems like a good place for this thread.
