Dennis Kirban
 - Mar 5, 2009
kirban 2 cents worth
On the trunk ID label. One interesting code is the VK3 which stands for front license plating mounting. On a quick run down on this lengthy post almost every trunk ID label shows it. However, my car doesn't as does a few other low number examples.
Since it was a no charge option, interesting that it is not included on every car. I don't know the count of states that require front plates versus states that only issue a rear plate. Perhaps Mr Salvage can give us the numbers as I am sure rear plate states are the smaller number.
Most cars today have the clean curved front ends, unless they have a "pop in" section look terrible with front plates. Corvettes and GTOs come to mind as looking weird with front plates.
Our cars almost did not need any bracket however, the front bumper does have a small curve in it which would bend a plate unless the front license plate bracket was installed. It was secured under the front lip of the bumper I think with 2 ten mm bolts. The top two bolt holes originally had two plastic extensions that kept whatever plate was bolted to it from being pressed against the face of the bumper.
I have the window sticker to my car and it originally sold in Pennsylvania which does not issue front plates - thank goodness. Reason no VK3 code.
kirbanperformance.com
denniskirban@yahoo.com
