Dusty. You just listed off a bunch load of compromises. If you don't throw cubes at it, you have to do this and that to get the turbo to spool. Compromises at every single turn. The person with the best set of compromises wins.
Wouldn't it be fun to be able to tune for maximum top end performance without having to worry about how it's going to affect the spoolup?
The spoolup tune would be a completely separate tune in itself with absolutely no need to compromise the top end tune.
I have to tell you, the parts suppliers are loving all this compromising stuff. It keeps the parts development departments busy and parts flying off the shelves. Instead of adjusting a few cheap jets to control the spoolup without affecting the top end tune, a simple change in a stall speed or camshaft spec, or any of the variables Dusty listed might call for a completely new set of compromises of all the variables involved. A snow ball affect, if you will. Wow. Better have a deep wallet for that type of racing. And how much did it cost me in trying different CRs, heads, cams, turbos, converters, gears, tires, cubic inch displacements, header styles? It cost me the time to develop an effective 2 stage nitrous system. A system that no one else in the world has ever seen.
Setup the engine for top end efficiency and dial in the nitrous system for spoolup and launch.
You're very right, Dusty. It is the easy way. Also, the less expensive way by far.
And, development of the nitrous/methanol ALS w/AB continues. :biggrin:
