Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
Found it.
SignUp Now!So I pulled the intake off so far and it looks like the gasket blew to the inside also. See picture. There was a little bit of RMI-25 visible in a few spots in the lifter valley so some coolant did get into the oil. I did not find any coolant at all in the oil when I drained it nor have I seen any coolant anywhere else besides in the lifter valley in the back corner near number 6. I kept the oil I drained from the filter in a glass beaker and there is no separation at all. Now the question is do I need to pull the motor out and tear it completely down?? I found nothing at all in the oil filter so would I not see material in the filter if I have a damaged bearing? I will probably pull the head off tomorrow after work.View attachment 239537
I am not sure why the rust is there around the port. Will have to look into that further.Sorry if I missed it but why is the head surface so rusty by the water port ? If you just pulled the intake it looks like it wasn't sealing.
Thanks,I'm in the same boat as you right now. As much as I hate to I'm pulling the motor. I've already dropped the pan on mine and looked at the 3 main cap bearing and it's like new. I never milkshaked my motor and my head gasket failure is nothing compared to yours. I just have a leak around the water port by #6 cylinder. No firing ring failure.
I just want it on the stand so I can do the job better, not to say it can't be done in the car but I also want to make sure my intake lines up with the heads properly etc. I was fighting my intake too so the only way for me to do this right and be done with it is to pull it.
Good luck with the job and hopefully you didn't hurt the motor.
I believe I have the Racetronix G7X with dual 255's. Will probably want to go dual 340's when I go to 120 or 160 lb injectors someday.Which pumps are you using on your double pumper? Twin 340s flow a ton if you want to upgrade.
Thanks,
By the time I remove everything needed to pull both heads with the motor in the car I am about 11 bolts and a couple of wires away from removing everything needed to pull the motor. I can borrow a hoist and I have a stand. Way easier to install heads and headers with the motor on the stand anyway. I guess I will be starting that process this week. I will tune for absolute zero knock in the future!
