SignUp Now!I heard you can;t run them without preheating the oil or something like that.
are you serious? preheat the oil? whoever said that to you rides the short bus. every critical dimension in that motor is set to deliver optimum performance cold and hot, with ideal area in between obviously. alum block motors have been around since the 20's, think they would have figured that out by now
And there are no disadvantages to running a TA motor on the street, they will even cool better than a 109 will. the only disadvantage to building the motor you want is the cost. and as a side note, an iron block only starts to come into an advantage when you start getting close to 1000hp, and thats production alum blocks. I couldnt imagine the TA block being at a disadvantage to an iron block until at least that point and maybe higher.
Gary
Might want to hold out for that Champion 4.1 iron block........Four bolt mains, and cross-bolted, if I remember right. Hmmmmmm............
Don't tell me believe what you read in the GS -Extra. I would bet that if TA gave one to the Club you would get a different story.
