I'm guessing being able to cut a 1.54 off the foot brake and running that same kind of spool up (125 shot) on the street is what caused this:
overdrive gear? (I don't know squat about automatic transmissions)
The little nub that is sticking out is from a shaft behind that gear, is that the output shaft? here are more picts:
The only other thing that concerned me is that this thing seems like its a little burnt or has wear on the back of it:
And the teeth on this seemed kind of worn but I dunno if that is normal:
Can I just replace the broken parts and go or is there a high probability of other broken stuff in this thing? I have my original BRF core in my shed and was considering taking some of the hard parts and putting it in this transmission. I just want to get it up and running while I gather the parts to put in a 400.
As a side note, that shaft that broke is TINY. I can't believe that is what is transmitting the power to the rear wheels. It's only about 7/8ths in diameter and hollow.
What kind of 400 would I need to stand up to the abuse I'm dishing out? I've been told that even a relatively stock 400 is pretty tough to kill. The car ran a 1.54 7.0@95 11.2@118 on the only quarter mile run I had a chance to do. That was with something like 55% torque converter slippage. I crossed the line at around 5100 in overdrive.
