Michael, maybe not but the heat and boost charasterics of the centrifugal would mirror this setup. If nothing else I'd be able to turn it on earlier and get more agressive with the timing earlier. With 7lb's and 140 deg inlet temps at 3,000rpm's, and 16lb's and 230+deg's at 6,000rpm's...... the required amount of water/alky flow would be quite a bit different. No reason not to try it with the parts just sitting around either, and nothing wrong with new ideas. The window may be more narrow, but there's always power to be had with the ability to tune more aggressively everywhere and with 7lb's as low as 3,000 it's still significant.
Todd.
