well, the problems im having with the ME is that i cant get it to run right off idle, or at idle. if i put it in gear, it stumbles, then picks up, but sometimes will die, especially if i put it in gear right after its started up. it idles OK, but has a horrible tip in stumble, when i add a bunch of cruise fuel and idle fuel, it goes into gear better, and doesnt stumble quite as bad, but then it is really sluggish, and gets horrible gas mileage. just feels really sluggish and seems like its laboring to get movin. once the tip in stumble happens and it smooths out, it pulls nicely, and smoothly, the turbo spools good, and it just feels nice. at part throttle boost it blows out tons of smoke, black smoke, on setting 4 on the thumbwheel. if i go full throttle it wont smoke so bad.. just alot of little junk, that takes alot of trial and error, to get it to work correctly, i want to send the chip to steve Y and see if he can reprogram it for my combination, i found i have a TA49 turbo instead of a stocker, like previously thought. might even be larger than that.
