Originally posted by DCVING 6
Why don't you want stutter? Is this where it holds out the stall a little longer?
That's why we were working on different stutter speeds during development.Originally posted by UNGN
Stutter sucks because:
1.) The stall speed of your torque converter may not exactly correspond to the stutter RPM
Well of course it isn't timed to the Xmas tree2.) The stutter feature is not synched to lights of the christmas tree, so sometimes you leave with the motor reving up (good) and sometimes you leave on a stutter (bbbbbad). Stutter may work if you get it to stutter then mash the pedal to the floor while it is studdering, then leave like that.
Neither is the Anti-theft feature something that comes naturally. But >75% of the Thrashers I sell have the anti-theft feature.I never tried it because it's not something that comes naturally.
UNGN, the 97 Thrasher I used for the first time (last time out with the T) listed Stutter and it worked ok for me. But I did not know what the feature was at that time and really do not remember the car stuttering at a preset rpm, although this chip listed 2400. Maybe this feature did help me since I mashed the pedal before launch and the other 3 times I have raced the tires began to spin when I tried to build boost too high (around 5 lb). I have a Thrasher 100 without stutter to test out so I can compare to see if the Stutter did help my inexperience in the launch technique.Originally posted by UNGN
Stutter may work if you get it to stutter then mash the pedal to the floor while it is studdering, then leave like that. I never tried it because it's not something that comes naturally. Maybe someone else has. I tried it every other way and loved the chip otherwhise, just hated the stutter.
I have some of the developmental 40pph chips and sold several years ago. But as I recall, Tom inadvertantly *screwed up* the cal on these chips as the car he was using as a test mule was in the process of eating #3E. He kept futzing with the fuel to try to correct a cam problemOriginally posted by tim87tr
Scott (mean![]()
) Do you know if any of the Thrasher chips will work with the redstripe 38/40s?
If you do not understand the benefit of having a car leave the starting at the same RPM consistently everytime in a bracket race - I guess there is no need to argue with you.Originally posted by Foolis
Forgive me, but I fail to see the real benifit / use for the stutter feature. As I understand, most Thrasher users are running 12's, and does one really need to use stutter to launch the car consistently?
Scott [that mean as*hole] doesn't work for Thrasher and crew. I am not going to rehash the Thrasher development story again...Also, why don't Scott and crew make chips for any larger injectors? I would love to try a back to back chip test with my car, but I have 52# ers!!
Available Thrasher chip calibrations - $25 each including shipping. The first 2 or 3 digits are the minimum octane requirement.Originally posted by Gokou
What's this someone mentioned about a 97 Thrasher chip? I usually run a mix of pump gas/race gas that ends up about 96-97 octane... I'm running a Thrasher 92 now and if there is a 97 I'd like to try oneAre the thrasher 009 going for $25.00??? I'm interested!!!
Originally posted by Scott231
I have some of the developmental 40pph chips and sold several years ago. But as I recall, Tom inadvertantly *screwed up* the cal on these chips as the car he was using as a test mule was in the process of eating #3E. He kept futzing with the fuel to try to correct a cam problem![]()
If anyone out there in TR world has used one of these developmental chips and wants to offer experience....I'm all ears. John Estill - didn't you try one of these 4 or 5 years ago?
Originally posted by Eric Stage I
The stutter won't work if the pedal is mashed to the floor. If the TPS exceeds 35%, it shuts off, or actually, it moves it to 6000rpm.
Eric
Dave, that would be great. I already have 40s in one car and have some used ones to install this winter into the other one. Scott, looking forward to hearing more about the Redstripe Thrasher possibilityOriginally posted by TurboDave
Scott, let me look through my list of Thrasher images from back when I was doing them. I'll go fire up my laptop and see what I have for 40's (I used to run them). You'll be welcome to any files I may have left.
Actually, it is the VSS reading > 0 that turns off the feature...allowing you to do burnouts. For the more complete explanation see http://www.thrasher-ep.com/chips_htm/stutter.shtmOriginally posted by Eric Stage I
