SignUp Now!How did you go about bedding the bearings, prior to measurement?
What was the method you used to take the measurement?
what brand of bearings did you use?
There is no good way of saying this, but before you go sanding. Measure the crank thrust width and measure the bearing. With steel main caps there could be two major issues. One being that the studs are binding in the holes of the main caps. The cure for that is drill them out. Second that cap may not be square in the block. That means that the cap was machined wrong or the machinist did not install correctly. If you measure everything first you may find that there are more issues than meets the eye. If the cap is crooked in any way you WILL have thrust bearing issues.
