Ticking Exhaust leaks, How do you guys pinpoint em?
V6UnderPressure
The Artist FKA Scott4DMny
I have an annoying ticking which I believe to be an exhaust leak. (Yes it could be the valves, but lets ASSume its the exhaust for now. How do you guys pinpoint where the leak is comin from? Any tips would be greatly appreciated.
Scott
exhaust leak
Top engine cleaner is good for finding exhaust leaks.
Don't try this in a closed environment.
Jeff
An old mechanic's trick is to get a section of heater hose (~4 ft)....put one end up to your ear...and go hunting.
John
Dip the vacuum hose from the charcoal canister into a little bit of brake fluid and watch where the smoke comes out. That is where your leaks are.
Does the sound go away when its warm up? If it does then you got a exaust leak.
