Richard, I believe you as I design, build, and test filters for a living. There are hundreds and hundreds of different media types to choose from these days that can really do an outstanding job of flow and filtration. Years ago I tested a paper filter and a K&N for a dirt track racer. We found the paper filter outflowed the K&N when new. We then tested a paper filter after a weekend of racing where it was really dusty and the paper did loose about 12% flow at the same DP, that weekend was not the norm and was a worse case. We did not test the K&N after a weekend of racing but have heard that they hold more dirt before losing flow. The dirt racer decided to change paper filters after every race rather than deal with the K&N. Alot of things need to be looked at when checking filters. Number of pleats is one, too many pleats are as bad a too few as they will be jammed together too tight and air will only flow through the tips.
Oh back on track, yes 12's can be done with the stock air box.
Richard, was that you at The Rock this weekend? I did not get a chance to talk to you if it was.
Jim
