Are you into the motor or just wondering if it's been replaced? Usually if it's been replaced the nylon gear on the cam would have been replaced also with a metal gear. If you have the chain off the gears, hold it horizontal by the end in one hand, the more it goes below the chains centerline in your hand the more worn out it is. Hard to explain on here, if you get a new chain and do this, compared to a used chain you will understand what I'm talking about. If you decide to do the timing chain, most of us do the valve springs at the same time, they wear out fairly quick, most noticeable if you race the car and lose power at the top end of the track do to valves floating.
Chuck
