That chain is fine. Personal experience says you need to replace it before it gets 100,000 miles on it. I would go ahead and drop the pan while you've got it down this far. That way you can verify there's no debris in the pan and pickup -OR- you can remove any debris in the pan and pickup. It's only 17 pan bolts and 4 exhaust bolts.
if the pan doesn't want drop clear, turn the crank 90 then 180 to swing the rear counterweights up and out of the way.
If you don't want to drop the pan, you can slide the dowels out of the block, put the cover in place and reinstall the dowels. Or you can get a can of 'The Right Stuff' RTV sealant and use it instead of that cork gasket piece.
