Hey guys,
I finally got the car running again and i went to verify timing and i got the base timing correct and then went to verify at 3500rpm.
The problem i found is that the timing mark bounces around at the higher rpm. i have it locked at 30* but it bounces from 28-32* when at 3500 rpm.
What is thae cause of this, is it normal (i don't think it is) and how do i go about fixing it.
Car is running xfi, xim and stock crank and cam sensors.
Thanks in advance,
Adrian
Thanks in advance,
Adrian
