boostmaster
- Aug 20, 2001
I've been having knock issues so after checking everything else I decided check and see if my actual timing was off. Used the piston stop method and discovered that my aftermarket crank is about 10* retarded from the stock crank. No it's not the balancer as I am using the stock hub. Is this normal for aftermarket cranks?
