TONS of stuff, performance, audio, stock, hotair...
BLACK MAGIC RACING
formerly turbo_canuck
Doing a massive cleanup, here's the big list:
86/87 PARTS:
-Stock crossover pipe-$ 35
-stock intercoolers (3) - $80 each
-turbo heat shields (2) - $30 each
-3.42 richmond gears - $90
-stock intercooler shrouds (3) - $25 each
-stock exhaust elbows (2) - $10 each
-stock inlet bells (2) - $5 each
-stock up pipe - $25
-stock wastegate actuator (3) $15 each
-turbo brackets (2) $15 each
-quarter panel extensions pair (non spoiler) - $20
-clear parking lenses - $15
-stock posi rear - $800
-stock turbo cores - $90 each
-stock front sway bar - $40
4 stock t-type wheels w/ caps - $275
front GN bumper - $100
pair gn lower door panels- $60
complete engine harness - $250
4 GN wheels w/ new caps- $300
2 85 gn wheels with broken center rings (good for slicks) - $100
stock gn valve covers - $60
stock dowmpipe (2) $20 each
stock fuel pressure regulators (3) $20 each
cut chrome turbo shield - $75
stock ECM - $75
a/c lines - $50
2 stock turbo cranks - $300 each
Blower motor- $50
Flexplates (2) - $35 ea.
Throttle body and plenum, no arm, spring or iac- $ 125
Cruise control unit- $ 40
EGR valve and solenoid- $ 50
Stock shifter- $ 30
Right side air dam- $ 25
PERFORMANCE PARTS:
March underdrive pulley kit w/intercooler fan- $120
Chrome moly stock length pushrods- $50
B+M line lock- new- $60
Pair of mint redone GTA rears- $ 225
New heated 02 sensor kit- $80
204/214 speed pro hyd. cam - $75
.030 speed pro forged pistons - $200
Pair of 8.5" vectors, centers painted black, holes drilled for screws- $175
Pair of 8.5" vectors, good shape, $250
Set of centerline auto drag high polished wheels, 2 15x7, 2 15x8.5 like new- $575
ls1 maf sensor - $85
Kirban variable rate rear springs- $60
red's double pumper w/ switch - $425, used for 2 months, track time only
4.10 richmond gears - $125
B+M torquemaster torque- 2800-3200 stall, th350,th400- $200
84/85 PARTS:
complete intake - $90
turbo/ throttle body assy. (core) - $80
engine accessory bracket - $25
braided down pipe - $20
INTERIOR:
Green Steering wheel- $80
grey dash pad - $$80
rear quarter window trim - $15 pr.
3rd brake light - $5 each
a-pillars for t-tops - $10
t-top wide front trim - $10
CAR AUDIO:
Alpine CDM-7861 flip face cd player- $150
Alpine CDA7863 flip face cd player- $ 190
MTX thunder4122 2 channel amp- $ 100
Memphis mono amp 16pr1kd- $ 250
Clarion 15"xw series sub in box- $250
FRESH LONGBLOCK ---4 RUNS:
10/10 stock turbo crank
billet center mains
RJC girdle
stock checked + magged rods w/ ARP bolts
.030 forged speed pro pistons, moly rings
comp cams 212-212 hydraulic roller cam + lifters, roller cam button
comp "beehive" springs, retainers, and locks
rollmaster timing set
comp hi-tec pushrods
hi-volume front cover
RJC head gasket kit
Fully race ported iron heads + port matched intake
manley severe duty stainless valves 1.77/1.50
t+d shaft mount roller rockers
cost me over $5000 u.s to build, sell for $4000, only 4 runs on it!!!
Line Loc
I will take it if its $60 bucks shipped. I can pay pal you the money.
Freddie I've got some Metco uppers here if you're still looking, but the Moroso trick front springs are sold. Email me if I can help you bud. Thanks & TTT for ya :)
I forgot to mention all prices do not include shipping. :p Homie_Telefrag, you got mail. Michael, how much are the uppers? DCVING, 60 plus shipping. if u get me a location, i'll get u a quote. thanks all. :)
pictures please an shipping to 07512 thankyou mike
i will take a turbo bracket! how much shipped, also can you send pics of your lower door panels?
I'm interested in the clear parking lenses for 15.00 ...if they're both in great shape w/ no cracks, I'll buy them. How much total w/ shipping to area code 75253, USA? Do you accept paypal or do you need a money order?
Thanks, The Darkside
sorry, i forgot to post that the clear parking lenses are gone...Antagon, i only have one shroud, and it isn't in very good shape, it's held together with zip-ties... :rolleyes: ll3lue, i'll try ti get some pix tomorrow.
Double pumper -sold-
stock up-pipe -sold-
quarter extensions, non spoiler -sold-
all wastegate rods -sold-
jeez, sorry Mike, i forgot all about you, will get some.
No biggy I'm still in Iraq! :eek: I don't rember if you take Paypal or not? :rolleyes: Please send the pictures to bariso@msn.com the army account has been gettin piccky with photos. Thankyou Mike :)
stuff for sale
I'm interested in the line lock and the richmond 3.42's.
I'm kinda new at this so I ned to ask you what is probably a stupid question... I have recently pruchsed an 86GN that runs high RPM on the highway. About 3000 rpm as opposed to the 2200 that it should run. I have been told that I'm probably running 3.73's and therefore I need to go back to 3.42's. If I did indeed have to swap the gears, is what you're selling sufficient for my application or would I need more stuff?
Please advise, I'm very interested and can pay asap!
Thanks,
Louis
Are you sure the converter is locking up. If not that might be the problem. I have seen cars with 3.73's and they dont reve quite that high on the highway, and also at what speed is it at when your taching 3K.
turbo39151, if you have 3:73's, you may have a rear from a hurst-olds or 442, or maybe someone just swapped them out. if you're sure that you have the 8.5, these 3:42's will work. But as DCVING said, your problem could be elsewhere.
The converter was locking up on the tranny before it was rebuilt and is now locking up as well. My RPM is 3k at 65mph. Feels like I'm in 3rd. But the tranny is freshly rebuilt with something like 50 miles on it. That's why I'm looking at the gears. (I haven't removed the rear diff cover yet but I'd like to be prepared...) Unless you guys have other suggestions??
If I were you, jack the car up and check the ratio first. Gear changes can be a pain to set up especially with the rear end in the car. What size tires are you running on the rear too? I still have a hard time thinking 3K at 65mph is from the 3.73's, my car revs about 3k at 75mph with 3.73's and 26" tires. Just my opinon. turbo_canuck I hope you dont think I am trying to disturb a sale, its not my intensions at all. Just trying to help. :)
