Robert Wilson
- May 26, 2001
What does 926.3 cc's work out to be with base fuel pressure of 44psi?
926.3 cc per second?
SignUp Now!What does 926.3 cc's work out to be with base fuel pressure of 44psi?
Doesn't the BSFC need to be figured into that hp calculation? Or, are you just picking a common number for that?
is that real wins, or cry until he gets the win?I was just looking at my sig today and was trying to decide who to cut so I can add Jason's wins this year.
Yes. I was impressed by it. I almost ran out of setting range for the slip. I was thinking, "Man, I'm going to run out of setting here if this keeps going." Ended up with a very low setting. That TC would definitely not work with my lower hp, small engine/large turbo setup. Waaay too tight.
I also came up with the same slippage through the traps. A solid 9%.
i came up with 14 percent over the entire run with no tire growth or parasitic
loss threw the trans.The trans guys say the drive train can suck up 4%
How about these numbers 3400lbs @175.46 1433.39 hpYou really need to ask a person who deals with dyno numbers day in and day out. A car with a standard transmission can be down in the 10% range as far as hp loss through the drive train.
His turbos advertised rating is 1550 hp That is only an 8 % loss
I also calculated chris and ted at about 11% loss
The one that amazes me is the cruz missles tsm car 3550 @152.9 990.0 hp
This is a gain over the advertised hp the turbo.![]()
Yes.So then with this thought (I agree BTW) we know we are holding the cars back to maintain traction through the 60' and beyond then using the fuel calc method we can pick a point in the pass where we are hitting it with full power. I think we all can get a good ballpark idea where everybody is at this point. I am not sure what is going on with your converter, but I know from my info I was running 8.4's and slowed down when more power was applied, only to find out with a change that I was leaving a lot on the table the whole time so with that said once the converter is working properly can you label a car making X RWHP because you could be making 1800 BHP and be loosing a ton through the converter at various points going down the racetrack.
Very good point Dusty. And, that is what I've seen with the sim.1/4 mph is the best way to tell about the hp from track #'s. 1/8 mph #'s are easily affected by what happens in the 1st 300 feet.
I can and have went the same mph to the 1/4 while the 1/8 was over 4mph off. It makes it look like you gain alot from the 1/8 to 1/4 on the passes where you don't get a good run before the 1/8 but the 1/4 mph is still the same. This can only fool you into thinking your making more power than you really are.
Either way, guessing hp from track #'s are for the ricer crowd. The car either runs the #'s or it don't.
The thing that can throw people off is trying to judge Brake HP using a timeslip without taking the incrementals into account.
As I stated in the other thread. You are using numbers that relate to a quick snap shot of the pass, or a small section of the pass.
How quickly, and how much power comes in early in the pass is going to ultimately adjust your math.
Really, the most accurate way to use a timeslip to accurately judge the rwhp of someone's car is to have very detailed information on the car and as much incremental data points along the run as possible. That way, you can see how much hp is being applied to the ground during different points in the pass.
If a person is only applying 400 to 500 hp at the launch, ramping to 900 hp 3/4s of the way through the pass, and then is only at his max bhp potential for the last 1.5 seconds of the pass, how is a quick snap shot of data at the end of the pass going to account for the fact that the car was laid down for the vast majority of the pass?
Excuse me. I have to get the car ready for this weekend. I've made a major change to the aux fueling transition range. I moved it much higher in the map. The first few passes, I'm sure will be duds until I get the transition range dialed back in.
They bust me on my sig, why?That was not my point my point was the results on the track vs the
advertised potential of the turbo.Thats a tribute to some of the best
boys in the country getting it done real world and that's why they bust you on your sig.
Because I'm not producing more than the 91mm is capable of supporting even though I'm using 1.835"/1.5" valves?
I'm not quite getting the point. So, are you saying that they believe I should be able to push this small headed motor to 1600 hp? Really? Do they really believe that? Is that really why they're busting me about my sig?
