SignUp Now!Yeah and go figure he is limited to TSO requirements. Imagine if he could drop 300lbs and run any configuration he wanted. Theres a lot more in it imo seeing he "only" posted a 1.346 60' . Ill bet a months pay the Mustangs arent 3450lbs.Dang. Wish you were local. There's some Mustangs to beat up on at my track. You'd be #3 at our track. 2 Mustangs are in the 4s.
Looks like 1600 bhp or a little under that.
The TC is freakin tight.
There is a little more at the launch if the tires are capable of holding. I would say mid 1.2s.
Tire growth seems to be more like 3 percent.
The power comes on like a bomb after the launch. Very impressive power curve.
Yes. I was impressed by it. I almost ran out of setting range for the slip. I was thinking, "Man, I'm going to run out of setting here if this keeps going." Ended up with a very low setting. That TC would definitely not work with my lower hp, small engine/large turbo setup. Waaay too tight.Tony's car is capable of another tenth in the 60' if the track is right. It's not an issue of enough power, it's an issue of doing what the stock suspension, radials and track conditions allow.
Now you see more about how the converter works. It's loose down low to allow spooling large turbo's and then locks up tight with rpm. Very few are capable of this behavoir.
I also came up with the same slippage through the traps. A solid 9%.
I agree, my setup would be a challenge. I'm not making nearly the torque down low that Tony is with his particular engine/turbo combination. That helps him a lot to get on the TC. I'm close to half the amount of torque in the midrange compared to Tony, with the nitrous!It's looser down low than you think. I can go another 500 rpm looser easily. No doubt it would be a tough set-up for yours but you could most likely use less of a hit to get the engine spooled. On the lower hp cars such as the 8.50 and slower cars, I have to play with the fin angle to keep them from getting too tight if they turn over 7000 rpm. There is so much adjustment in this converter I use it from stock engine TR's to twin turbo big blocks. Once the engine size reaches near 600ci I go to the 10.5.
Tony, Dave and Cruz are all 3450#, stock suspension, radial cars. Not much of a comparison to tube chasis Mustangs.
That's an interesting guess Bison. What do you come up with for Don W's car?
I would like to see that done with Fear. What do you need?
I figure my car would chassis dyno at 885-944 rwhp, depending on the actual drivetrain losses. Less of a rwhp figure if the losses were beyond 25% which is totally possible when you're talking about racing TCs.
