Have a JW "the wheel" certified flex plate, using a Pro Torque 2800 stahl D-5torque, the flexplate has 7/16 inch holes and the torque uses 10mm bolts ,am I going to have to modify the torque to 7/16 threads or over drill the flex plate and install flange washers. I would think that much clearance in the bolt register would not be good and I would need to do something. Thanks.
