SignUp Now!Originally posted by 6PacktoGo
They are not one bit better than a good set of Speed Pro file fit rings that are properly gapped. I've never seen ANY verifiable gain in HP or reduction in blow by or leakage on the dyno or in the car, ever, not in 20 years. I've seen more problems with them than I've seen anything else. From my experience they're a gimmick at best, and at worst a crutch for another problem.
Originally posted by REDS HOT AIR
you need an engine dyno...a real one not desk top dyno.
total seals are speedpro rings with one notched and a second ring fitted in with it to cover the gap..
the higher the cylinder pressure the more difference you will see in total seals v/s non total seals
I DO own a dyno, DO YOU?![]()
Originally posted by KLHAMMETT
this is what i have been TOLD by a reputable builder, it cant hurt to use a gapless ring on the second ring,but dont use them on the upper ring,reason being that when detonated there is extreme heat that gets between the 2 rings and actual;ly twist the first ring because it cannot relieve itself,causing it to hurt the cylinder walls
Otto
