TPS question
Paul Clark
Idle setting is fine.
.40 engine off and .42 engine on.
So is WOT if I try to break my leg and stick my foot through the floor.
Since I don't do that very often, but I do "occasionally" floor it - but not to that extreme - I was wondering if maybe I should try to set the WOT adjustment a bit higher than it is now.
Paul
Depending on what your WOT TPS voltage is, you should be fine as 'most' all chips have the same TPS fuel addition units from 75% up or at least within a unit or 2 of the 100% value.
HTH
tps
Hi,
You're stuck with whatever WOT sensor value you have if you don't want to affect the closed throttle value, which I don't think is a good idea. Poston sells a TPS module that bumps the voltage higher at a lower throttle opening, but I have no experience with it.By the way, TV cable adjustment can make a big difference in your ability to get true, full throttle.
