Toddmc66
Import punisher.
- Dec 26, 2012
I'm using the Fast XFI 2.0 system and recently I've come up with a tps error. The problem is the voltage is dropping off after the engine is started. I can set the tps at .44v with the engine off and the pin out voltage is the same at the ecu. (BUT) the voltage isn't steady, it jumps or hunts up and down from .44v to as high as .47v or as low as .42v . It won't stay a steady at .44v I checked grounds and for continuity to positive and ground and didn't find any reason for this. Once the engine is running the voltage drops to around .23v to about .28v Something seems to be pulling the voltage down. This is a new problem because I've had the Fast system on if for a while with no problems.Has anyone run into this with or without the Fast system.
