SignUp Now!Do you still have ac?I keep mine in the glovebox so it's away from the elements![]()
Cool. I was wondering how to get the wires through the fire wall. Sorry for taking the thread of course.Nah no ac or heat
I run waste spark with .040 gap at 25+psi of boost. No issues with spark blowout. NGK UR5's. With a larger turbo and better heads, I'll tighten it to .035 as long as the lean cruise still works well at that gap, and will switch to NGK YR5's at that time. I should use YR5's now, but why mess with a proven combo?
Just completed a 150 mile trip and got 17 mpg on hwy. Thinking of opening the gap on UR5's to .040 from .035. Any opinions? I have an extender chip without lean cruise mode (that I know of).
Stock cam. 60 lb injectors, 3200 stall, 3" downpipe/exhaust....I guess I have a lot working against good mileage.The wider gap won't improve the mileage, but it may make the lean cruise smoother if you have any issues at all now. What cam do you run? That's when my mileage took a dump. I still get 18.5 on average and can get over 20 if I drive with an egg under the go pedal with a Erson 208/208 FT.
At least I have a lock up converter. Was going 75 mph at about 2400 rpm.
Same tires as yours, properly inflated. Windows were up and a/c on. Not sure about the O2 sensor.
