SignUp Now!I completely disagree. The radials will be quicker. They are less forgiving than a slick. For the average TR, a 275/60 MT DR and an airbag is all that is needed. I had no problem getting high 1.48 to 1.51 60's with a high 10/low 11 sec stock long block car launching at 7 to 8 psi on an average prepped track on street car night with no other suspension mods. The trick is to play with air pressure, and ease into launching with boost. Most start too high, or insist on using a transbrake which is a no go for a radial and no serious suspension work.275/60 for the street and 28x9 ET slicks for the track is what I do.....if you want the best track times you'll need slicks
To each his own....I completely disagree. The radials will be quicker. They are less forgiving than a slick. For the average TR, a 275/60 MT DR and an airbag is all that is needed. I had no problem getting high 1.48 to 1.51 60's with a high 10/low 11 sec stock long block car launching at 7 to 8 psi on an average prepped track on street car night with no other suspension mods. The trick is to play with air pressure, and ease into launching with boost. Most start too high, or insist on using a transbrake which is a no go for a radial and no serious suspension work.
I removed my rear arms and welded 1/8 inch steel plate to the tops of them. New bushins and some paint. No more squirmingHow do I box the control arms ?
Much better to just replace maybe?
How do they look on the car I have a friend he runs the 275-60 and they look funny to my eye like balloons the side wall is so tall. Not bad but just out of sorts ... Never was crazy with the look on my TA either .., I think the car would look better with wide tires out back though.
You should go mid 11s with whats in your sig, as long as you can get the DRs to Hook and the tune is good.Your Car looks good man .
I hope I can at least get a mid 12 with my set up first time put this May.
That would blow my mind if it ran in the 11s!!
Wondering if I need to replace the stock radiator ? I know last summer it would get to 210-220 pretty quick.
I don't see why not, you got more than I do and I swear my next time out I'm getting that 11That would blow my mind if it ran in the 11s!!
I don't believe Toyo makes a 275/60 or 275/50 in 15"Toyo looks good but I did not see any for 15 inch wheels.
