When you use a race chip designed for high boost/ high octane, 30psi is often hit, even with a stock motor. When your MAF gets maxed out, which is around a "low" 20psi, the computer will stop adding fuel. I run a chip from Red Armstrong. He asked me my build up, and how much boost I want to run. I told him, at least 27psi. So then, I use Direct scan to tune. Try a run @27psi, with C-16 fuel. If no knock, and rich, I go up in boost. I fine tune with a 7th injector and an alchohol inj.. My Red Armstrong chip will guess at fuel after around 20psi, and dump in fuel for much more boost. A street chip will not do this. Also, if I try to use a race chip on the street, it will run way rich for this reason.
Make sense?
Make sense?
