Apr 2, 2002 #1 4 4cd-Air Guest The trans tries to shift into a higher gear before it needs to, and seems reluctant to downshift. Fluid is right. Is something going out?
Apr 2, 2002 #2 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 Sounds like inadequate TV pressure. Have you checked your TV cable adjustment?
Apr 3, 2002 #3 4 4cd-Air Guest Originally posted by MeanBuicks Sounds like inadequate TV pressure. Have you checked your TV cable adjustment? Click to expand... Where and how?
Apr 3, 2002 #4 C Carolinaturbot6 Pride. Freedom. America Joined May 24, 2001 Messages 285 http://www.turbobuicks.com/ubb/Forum1/HTML/001384.html 4cd-Air, there's some pretty good instructions at the above link. If you need some more help just ask. That's why we're here bud. HTH http://gnttype.org/techarea/transmission/tvcable.html Here's another from GNTTYPE.
Apr 4, 2002 #5 4 4cd-Air Guest Thanks guys. Now the problem is the bottom end is bad. I think the machine shop pressed a wrist pin wrong...
