JDSfastGN
- Jun 16, 2001
Ok I just got my transmission back together after my dad and I rebuilt it and everything is prefect exept it starts out in second gear. i went through this last rebuild when I had little metalic debree clogging my valve body. I cleaned the whole valve body peice by peice and all worked fine when I put it back on. I also cleaned the PR and Tv boost valve in the pump and made sure it was all working and not jammed up. It starts in 1st only if I'm going from park or reverse into drive, other wise it starts in second. Here are the pressure readings.
Min TV 1500 rpms
P--------80
R--------150
N--------80
OD------80
D--------80
2--------230
1--------170
Max TV 1500 rpms
P--------260
R--------220
N--------260
OD------220
D--------220
2--------220
1--------160
I have an art carr shift kit, 3 spd 200 servo, PTS pump with the bigger tv and pr boost valves. The rest is all the billet internals. It is definatly not the band being too tight, it is actually a tiny bit loser than we usually set them up. Thanks for any help or input, BTW no the PR valve is not in upside down. Thanks guys
Min TV 1500 rpms
P--------80
R--------150
N--------80
OD------80
D--------80
2--------230
1--------170
Max TV 1500 rpms
P--------260
R--------220
N--------260
OD------220
D--------220
2--------220
1--------160
