If they are the STANDARD brakes which have the 10.5" rotors with single piston calipers they will. Everything but the spindle and brake hose is the same. If you are refering to the 12" 1LE than look back through the threads in this forum for what you can use. Basically just the rotors unless you are wanting to use the calipers in that case you need a lot extra parts.
