trans book and more trans problems
FlyinGN
all show no go
Last month I really zinged the GN and it shifted perfect. The next light it started to really shifting late and not going into 4th gear. Like the TV pressure went thru the roof. Just recently I had Bruces High pressure regulator system and a new 1-2 accum spring kit installed. It shifted perfect after the install of these parts. So Bruce gave me a few pointers to investigate and heres what i found..
* pulled the pan and did not find the governer spring in the bottom of the pan like I thought I was gonna find. I pulled the governer and the spring was intact.
* looking at the TV cable bracket I noticed that the 'hairpin' clup and the long blur spring was 1/2 out (where it was sopossed to be) inbetween the tv bracket. I unbolted the tv bracket and pulled the roll pin and the regulator thinking that the TV valve was stuck. I put in a pencil magnet and found the valve seemed to be free.
* I understand that the 'hairpin' and spring holds in a ball in the VB which is there in case you break the tv cable the tv pressures go full pressure instead of low pressure by defualt.
My questions are-----
1- HOW do I put this 'hairpin' and spring back in?? Where the heck does it go?
2- could this being out be that cause of my no shift/late shift?
3- whoo and whee can I get a book on the 200 trans? So I can get this bad boy back in??
3- now it seems the tv cable has lost all it tension. The tv bracket in the trans is not even touching the tv valve rod anymore. Should it be? Is my tv cable broken?
I know these questions are hard to understand. But I hope somebody can help. Bruce fielded 5 phone calls from me today and he had helped me BIG TIME. Thanks Buddy!
1. 2. 3. 4. The hair pin would be to hard to explain as would putting the bracket it's self back on the right way as it is very easy to put that back in incorrectly as well which sounds like what you might have done causing the slop in the cable. The check ball being seated could cause your prob and the manual you need Bruce sells. I can find, scan and e-mail you a pic of the bracket and link, if you would like?
YES! please do!!
THanks!!!!!
YES, Now how do I get the ball back in place in the VB so I won't get full tv pressure anymore?
The ball should be fine as long as you get the lifter rod and spring back in right, or if you want to and is recommended to remove the ball and lifter rod completely from your tranny.
Im assumming I have to pull the VB to remove the ball?
If I eliminate the spring and clip like you recommend, How do I get the slop out of the tv cable?
THAT IS WHAT I TOLD HIM!!!!! ROFLMAO!
:D:D:D:D
Yes, Frank and I spent some time on the BAT phone today......:)
Bruce
WE4
if you don't feel comfortable dropping the VB then you can just leave the liter rod in it's up to you. As far tightening the cable follow the procedure in the 1st diagram I sent you.
okay.. Thanks again guys.. Both of you helped a lot and it is appriciated.:)
How do I get one of these 2004r books from you Bruce??
Well call the shop....
I may even trade it for "that green bikini" and I know you KNOW what I am referring to. ROFL. :D:D:D:D
Bruce
WE4...
