Well I can give a little input here.
You are doing the exact same thing as a neutral drop with that SR brake. The roller clutch takes the load and EVERYONE we and other shops have pulled out and cked , the springs are all rolled over in the sprag. Save yourself the 200 bucks and just neutral drop it . Same thing.
Now, The Bat Brake Holds the low clutch on release so the sprag doesnt see the load. It also utilizes low gear like normal. Also, the rest of the trans is built around the brake. Direct drum and center are highly modified and it is one serious piece. Not a novelty Piece.
Just for info release time is .028 seconds, for the record.
You must also take into consideration the shifter cable, detent cone and linkage wear when "striking" the shifter to leave. Not to mention you are going against the g force trying to shove forward, leaving. The Bat Brake will not rock or roll thru lights. Rear end backlash does play a slight part here with any brake.
Chris718 makes a brake too and again, he was smart to protect the sprag. No offense, but the with SR brake you are basically building a bomb. Talk to Chris, to Lonnie, Vince Janis or Eric Shertz. You guys need to look at what the big boys are running. Eric Shertz FOR A FACT I know runs a Bat Brake. Lonnie does too. Scott you do too. Vince Janis does, Red Armstrong does, so with that in mind, there must be something to it. Also, I can speed up release time or slow it down. Lonnie bitched for a year about how fast it was cause he kept red lighting on a pro tree!!! NOW ...That is saying something there buddy!
The Bat Brake works absolutly normal in street auto mode and if installed in any car, would never know it was even there .
No matter what Brake you do choose, please remember, especially if you have ever seen one come apart, to protect it with a trans shield. Blankets are ok if you can install some styrofoam or something of that nature, to keep blanket from sealing in heat. NHRA and IHRA are both very much aware now that these products are available for our cars so be careful with tech. Safety should be first.
TRANSBRAKES AND HEAT GENERATION go hand and hand. ALWAYS install the biggest cooler you can and as much sump volume as possible. ALWAYS have the cooler in front, fresh air flow. Never repeatedly lauch Brake on street without suffecient time to cool down. Heat will kill.......... that is a promise...
I can answer anything you could ever want to know about the BATBRAKE. just ask.....
Oh to answer your first question, what is the deal? The deal is technology which costs Money vs what can I get by with?.... That is the bottom line..........Hrrmmm Imagine that?
Bruce
WE4
