ok i have been running a external trans cooler on my car for sometime now. well now that im start to do alot more mods and the trany has just goten rebuilt and has a PTS billet 3,000 9X11 i want to make sure my cooler is up to the task. right now im running this one and im not sure if its good enough.
B&M SuperCooler Oil Coolers: BMM-70268 - summitracing.com
i was wondering should i upgrade or should i plum the trans line into the bottom of the PTS alum Radiator then have the top line going to my external cooler that leads back to the tranny. the PTS radiator is very efficient at cooling and having the trans cooler after that would knock off more head correct. should i do this or go with something like this
B&M Hi-Tek SuperCoolers with Fans: BMM-70297 - summitracing.com
if not that what do you recommend. thanks for the help
