Steve Poppleton
- Aug 24, 2015
X2 on the post radiator . And I wouldn't run a stand alone. Water/coolant is a better conductor than air. Stick your hand in a bucket of water and then wave the other hand around as violently as you can. Which hand changed temp to the cooling medium? Yeah the hand in the bucket. Even if you hold your hand infront of a fan or out the window with the vehicle travelling at hwy speed.
I go through the rad, then through two aux coolers on the T.
Sent from my HTC PH39100 using Tapatalk
I've always thought running your 150-160 degree trans fluid through a 190 degree radiator was a bad idea. I've always preferred a standalone. Is my thinking flawed ?
