Trans cooler
good afternoon everyone I’m getting ready to swap out my trans and want to do a good cooler and I’m wondering what brand i should get and one with a fan or one with out one i appreciate any input thanks
I'm getting ready to put a B&M 70264 super cooler on my car as the transmission is being built up. It will be situated down low where the current slic is to catch the air coming from in between the air dams.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Are you running the lines in an fittings and braided lines
Sent from my iPad using Tapatalk
I have a derale trans cooler works great. Has it’s own fan. I mounted it in front of front passenger tire! It came with the hoses and fittings to work! If you mount it vertical make sure your return is on top so it fills from bottom up.
